Converting two bolt main block to a fourbolt main...
Old Oct 2, 2006 | 07:35 AM
taylorcrzy's Avatar
Is it possible to convert the block over to a four bolt main with the motor still installed? Other than dropping down the K-member is it possible to do it? Just curious if anyone had tried to do it.
Old Oct 2, 2006 | 08:48 AM
sssalah's Avatar
Re: Converting two bolt main block to a fourbolt main...
Not possible. It'll need to be align bored/honed in a machine shop.
Old Oct 2, 2006 | 09:02 AM
engineermike's Avatar
I second that motion.
Old Oct 3, 2006 | 11:20 AM
taylorcrzy's Avatar
Thanks for the reply.
Old Oct 3, 2006 | 01:56 PM
wrd1972's Avatar
Only if your a magician.
Old Oct 3, 2006 | 02:08 PM
confused327's Avatar
why would you want to, switching from a 2 bolt to a 4 bolt doesn't really matter untill you are making a good amount of power, enough power where you would have to have the motor out to accomplish it.(excluding power adders)
Old Oct 3, 2006 | 02:35 PM
The hardest part would be trying to fit a machine shop underneath the car.
Old Oct 3, 2006 | 03:25 PM
sbs's Avatar
sbs
Clearly he already has that part solved, in order to do enough engine mods to require a 4-bolt in the first place...
Old Oct 3, 2006 | 08:33 PM
FastLt1's Avatar
You could probably do ARP studs without removing engine and be as strong as stock 4 bolt.
Old Oct 4, 2006 | 09:18 AM
bmwmcars's Avatar
Not sure if this is accurate or not, but 3 machine shops have all told me that even doing studs requires line bore/hone, since it changes the clamping force applied to the caps.
Old Oct 4, 2006 | 07:45 PM
FastLt1's Avatar
Best listen to them. It was just a thought. I did it on a old SBC. But didn't know about torque plates and align honing. Just wanted something harder to blow up.
Old Oct 5, 2006 | 12:49 AM
rskrause's Avatar
Moderator
That is accurate. It needs to be align honed if you install studs.
Rich
Old Dec 20, 2006 | 02:53 PM
taylorcrzy's Avatar
Ok, I will just build a spare block and stroke it then pull the original motor and swap everything over and reinstall the new motor. Thanks
HectorM52
Jul 30, 2017 11:46 AM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
