converting to elec water pump
Old Mar 26, 2009 | 02:21 PM
whyrun's Avatar
I'm starting final assembly of my engine and it will have a elec water pump, Is there a process of blocking the hole in the block where the water pump drive used to be. I would think if it was left open there could be to much oil splash onto the timing chain assembly, causing parasitic drag. or is it even a issuse?
Old Mar 26, 2009 | 02:48 PM
Stl94LT1's Avatar
No need to plug the block.
Old Mar 26, 2009 | 07:18 PM
jhthornley's Avatar
leave the part that protrudes from the engine. Just remove the connector piece that "mates" the protrusion from the engine to the one in the water pump housing... doh... if you're insatlling electric, you've got to remove the mechanical one anyway, so like the first guy said... You don't have to do anything. Just leave the part that sticks out of the engine alone.
HectorM52
Jul 30, 2017 11:46 AM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
thenewkid
Nov 27, 2014 09:41 AM
