Converting block from obd1 to obd2
What is needed make an obd1 block hook up correctly to all sensors in an obd2 car? I know there were a few changes, and I will be going from a non vented opti to a vented. I am buying a longblock to build my new motor with and am just trying to figure out what I need to do to get it to work in my 96. Thanks.
The blocks are the same. The 96 has a different knock sensor in the passenger side of the block and an additional knock sensor in the drivers side of the block, the timing cover has a provision for a crank sensor and the cams are different to work with the vented/pin drive opti. The coil and ignition module are different(not sure how). The rest of the sensors are the same.
If you want to use an OBDI engine in an OBDII car and have it hook up like it did from the factory, you will need The front cover from and 96-97, as well as the crank pos sensor and the reluctor ring. In order to drive the vented opti, you will also need a cam for a 95-97 as it is driven of a dowel pin, not a spline like the 93-94s. The block itself is the same, all LT1 Fbodys use only 1 knock sensor on the passenger side, however you may need to change it, as they list 2 different part #s. So if you still have the engine from the 96 you will need to switch out those parts.
Correct me if Im wrong though.
OBD-I uses a 4.5Kohm KS, OBD-II uses a 100Kohm KS. The PCM can be modified to accept a different sensor than it was intended to use.
If you are using the block from an OBD-I car, to replace the block on an OBD-II car, you simply move all your accessories and sensors over to the new block. Nothing else needs to be done to it.
stockssn2o
May 25, 2015 08:54 AM
ChrisFrez
Feb 15, 2015 07:49 AM
