converting '94 opti to a '95
Old Jul 3, 2012 | 07:43 PM
dzltek's Avatar
Other than a vented opti, what else is involved in switching one over? I'm buying an engine out of a 94 and gonna put it in my 95. Also will it be as easy as remove and replace or do need to do before I install the other engine?
Old Jul 3, 2012 | 10:20 PM
Re: converting '94 opti to a '95
Lots to do.
Old Jul 4, 2012 | 08:40 AM
dzltek's Avatar
Thanks shoebox. I take it I can't just drop the engine in and plug up the 94 opti with my 95 harness if I wanted too. And sense I have a new 94 opti I could take it back to auto zone and get a new 95 one and have a new one. I can use what's needed off my 95 engine though, correct?
Old Jul 4, 2012 | 09:03 AM
96capricemgr's Avatar
Just get an MSD cap and rotor kit, it adds a vent line.
Old Jul 4, 2012 | 09:31 AM
Pullngz's Avatar
If you still have your '95 motor, you need the '95 timing cover(new gasket and seals)
You will also need your '95 timing set, or a new one if yours is worn out.
You need your '95 cam(it has a longer dowel pin to drive the vented opti.) The '94 is spline driven
That is all I remember changing on mine when I went from a '94-'95 opti
Old Jul 4, 2012 | 11:54 AM
dzltek's Avatar
Thanks guys.
blkWidow
May 3, 2015 08:42 AM
thenewkid
Apr 12, 2015 07:42 PM
ChrisFrez
Feb 15, 2015 07:49 AM
