Confused, need help on where these go
I pulled my intake to fix the leak and its been a couple of weeks since I last looked at it and forgot where these went. I have everything mocked in place (i hope) except for these two. Can anyone help me out. (Pics of it all together so i can reference would be great)
from www.shbox.com if you haven't seen the site yet, learn it well
He has tons of great pics and other things for reference
I started going through there after I posted and saw some that helped, but its always nice to see it explained too. Thanks for the pic. There are two coming off of that, one with the big rubber 90 on it, where does that and what does that attatch to. And the small hard line goes into the rubber hose coming out of the fuel line right?
The small single line goes from the driver side top plug(where theres a triangle of 3) back to the EGR valve then im assuming? It has two plugs on the one end....thats where im confused
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The rubber 90 degree connects to the throttle body. I think you should be able to tell which outlet based on the size. I can't recall from memory exactly which one.
And then the hard line wraps under the TB and connects to the rubber line bundled in with the fuel linesIm not really thinking straight...it was a bad start to putting it all back together. My buddy snapped the head off of one of the bolts that holds the pan on the bottom of the intake on...i about killed him
I labeled everything when I fixed my intake leak. It's virtually impossible to remember where everything goes unless you've done something several times.
One more question, I found it once but cant find the proper way to torque the intake down. I know its inside out and 35lbs once its all done but there is a numbered pic out there somewhere
Nayr
Mar 3, 2023 08:34 PM
