Confused about LT4 knock module...
Old Nov 28, 2005 | 08:08 PM
GreenZLT1's Avatar
Question Confused about LT4 knock module...
I have been searching and some people say it will work in my car and some people say it wont work..
Will it work? I got headers and plan on getting 1.6 roller rockers..
Rob
Old Nov 28, 2005 | 08:20 PM
Schweet97Z's Avatar
Re: Confused about LT4 knock module...
it will work ......
Old Nov 28, 2005 | 08:24 PM
turbo_Z's Avatar
It might work. Really depends if you were getting false knock before then tehre is the possibility you will get less false knock if not no false knock after.
Old Nov 28, 2005 | 09:18 PM
OBE1 95Z28's Avatar
The knock module is a filter that "ignores" mechanical noises and allows signals that "sound" like knock to be delivered to the PCM. The LT4 made different mechanical noises that the LT1, as it came from the factory with GM RR's. It's likely that the LT4 KM will help ignore your RR's; it's a maybe if you header mechanical noise is filtered out by the module (the LT4 didn't come with headers from the factory).
Nayr
Mar 3, 2023 08:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
