Compression Check (PSI readings)
Old Dec 31, 2003 | 07:00 PM
chad_g69's Avatar
just changed my plugs after 15,000 miles (1st time after rebuild) with bocsh 4+4 plugs and MSD 8MM wires
did a compression check, below are the results
1 - 245psi 2 - 246psi
3 - 248psi 4 - 247psi
5 - 250psi 6 - 248psi
7 - 246psi 8 - 243psi
lowest: 243psi, highest: 250psi (7psi varience)
this is still good right?
(tested while on battery charger @ WOT, all plugs removed)
what is the normal for a stroked engine?
Old Dec 31, 2003 | 08:45 PM
Josh-'04 GTO's Avatar
As long as all cylinders are basically the same ( I think +/- 5% is tolerable), so your motor is fine.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
