compatibility of CSR electricwaterpump & Becool radiator
the guy installing my becool says that the rad is 1" thicker than the stocker & he can't get the fan back on. i called jegs & they say that they should work 2gether. i also called becool & csr, but they must be closed. i'm getting the dimensions from jegs 2day & will get them from becool on monday. then i'll go to the install shop and see if i have the correct one. any thoughts or opions would be appreciated.
Re: compatibility of CSR electricwaterpump & Becool radiator
Originally Posted by FeelTheSpeed
Yeah it should fit, fit on mine fine....just remember to take out the water pump drive shaft. I had some crazy problems with that.
Originally Posted by axehead
so you guys have both? csi ewp & becool rad?
Ya will HAVE TO notch the fan shroud to get it to fit and modify the top plastic cover and bottom tray the radiator sits in. If ya don't the bottom tray will rub a hole in the tanks and the top cover will let the rad flop around.
It will fit,I got more rad and WP than you and mine fits. Had to MAKE it fit and you will have to do the same.
WTF is wrong with todays mechanics? If it don't unbolt and bolt back in then they are lost.
Recon the never heard of a little fab work or grind and fit.
IT's call "IN FIELD MACHINE SHOP INC.".
i beleive that its the wrong radiator. i won't know for sure until monday when he opens (he's closed on sat & sun). but he claims that there is not enuff room for the fan to even fit between the pump & rad.
I found out today from becool that their radiator IS NOT compatible with an EWP. i decided to keep my EWP & go with a new stock radiator. i hope that this saves someone some trouble.
Why is it not computable with an EWP?
Originally Posted by Kevin Blown 95 TA
What problems did you have bro? I took mine out when I did the WP, but I always wondered what would happen if a guy left it in there, cause some do and CSI don't tell you not to.. Get the gears chewed up from rattling around from having a bearing on one side and just a seal on the other?
the becool radiator is about an 1 1/2" thicker than the stock radiator. and since the CSI extends further than the stock water pump, it didn't leave enough room for the fan to fit between the two.
It wasn't a bolt in but it fit and is in there and looks neat too even modded the top plastic cover and used it.
