Comp XE Users Inside
What springs are you guys using for these aggressive ramps? Rates and pressures would be great (Details!). Also, what lifters as well....Thanks!
I have the XE230/236. I had the machine shop use CC987's double springs I think. The head did have to have a little machine work to allow the spring seats to work properly.
The machine shop did the heads so I know nothing about pressures or heights.
I am also using the stock lifters. I use this car mostly on the road course and it has worked perfectly so far and this runs the car at High RPM's for extended periods.
I'm going with a 230/236 and 1.7 scorpion rollers (puts lift at .578/.589 I think). Combination Motorsports says their 612 springs are good for .600 lift so I should be fine. with them, and they are considerably less expensive than other springs I have seen
