Comp Hi-energy pushrod question
Old Feb 21, 2008 | 11:25 AM
94TEALz's Avatar
I searched but could not come up with a good answer. My 94z has the cc306,918's (10 deg.),comp pro mag 1.6 rr, and trickflow guideplates. I b ought the comp hi-energy pushrods but dont think they are hardend. Can someone shoot me a quick part number on a decent pushrod that will work with this combo?
Old Feb 21, 2008 | 12:15 PM
truedualws6's Avatar
Comp 7940-16 are the standard (7.20"; 5/16") length chromoly pushrods.
Probably about $120.
Old Feb 21, 2008 | 01:00 PM
The Engineer's Avatar
If you're buying new push-rods, it probably wouldn't hurt to first remeasure everything to make sure you get the "exact" correct length.
Decking the block, grinding the valves, small base-circle cam, Etc., can significantly change the LT-1 OEM 7.200" baseline.
WD
Old Feb 21, 2008 | 02:04 PM
94TEALz's Avatar
ok well looked up the part # and 7808-16 seems to be hardend for use with guideplates? can anyone confirm this?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Roadie
Feb 16, 2015 10:34 AM
