Comp cams 978 springs or 987??
Old Aug 25, 2004 | 06:57 PM
Quick96Z's Avatar
Comp cams 978 springs or 987 for 383??
Which of these two springs would be better for a 383 with a custom ground cam with specs that will be close to 239/245...577"/.576" , 112LSA. I understand that both springs require the head to be machined to fit and they both require different seats and retainers, i just want to know which one seems to hold up the best. I'm expecting consistent 6500 RPM use, and i want valve float to be the last thing on my mind. Also, what kind of springs do alot of you 383 guys use and what kind of RPM's do you guys typically see. Thanks guys!
trav
Old Aug 25, 2004 | 08:37 PM
PoorMan's Avatar
Re: Comp cams 978 springs or 987??
I am running the 987 springs and at my installed hieght (1.800) I am good to .600 on paper or about .580 to be safe. Lift in sig. I only rev to 6200rpm and have never had float with this springs with my set up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
