Comp Cams 918 spring failures !!!!
Old Jun 13, 2007 | 11:29 AM
AZ2ENVY's Avatar
I am posting this here for those of you that havent seen this yet .
Theres a TON more 918 spring failures happening all over different
forums Looks like there might be a class action lawsuit in
Comps not so distant future IMO Unfortunately my batch
# for my 918's are the same as other reported failures , # 49826
Ill be pulling my valve covers to see if i have any broken 918's ...
http://www.ls1tech.com/forums/showthread.php?t=717173
http://www.ls1tech.com/forums/showthread.php?t=728938
http://www.ls1tech.com/forums/showthread.php?t=728254
Old Jun 13, 2007 | 12:00 PM
Colin91Z's Avatar
This is making me nervous...I don't have the box that my 918s came in anymore, but I do have a pic of the box from when I first bought them. Problem is I don't know how to zoom in so I can read the batch #
Can someone help me zoom in on my batch # please? I'd like to find out if mine are any good before I start my motor for the fisrt time
Here's the only pic I have...
Old Jun 13, 2007 | 12:05 PM
speed_demon24's Avatar
Mine are batch # 051791 . I have my new springs sitting next to me waiting to go on though.
Old Jun 13, 2007 | 12:43 PM
Nitelite's Avatar
I can make out part of it... I think.
XX597, I cannot make out the first 2 numbers. It's very hard to see from the flash of the camera.
Old Jun 13, 2007 | 12:55 PM
Colin91Z's Avatar
Yeah it's hard to read. Thanks for the effort though
I really wish I had kept the box or wrote down the batch # or something now
Although when I bought these in 03/06 there were no reports of failure...
Old Jun 13, 2007 | 01:55 PM
AZ2ENVY's Avatar
There has been reported 918 failures back to early 06' .
Old Jun 13, 2007 | 02:19 PM
jasonisdn's Avatar
send me the photo. when you post it , it cuts back on quality and i can clean it some but not enough to see it great. jmcalister2@triad.rr.com
Old Jun 13, 2007 | 03:48 PM
maybe2fast's Avatar
this is a bad bad thing for us performance guys. I hope my springs are okay...I wanted the best so I bought 918s...
Old Jun 13, 2007 | 04:01 PM
AZ2ENVY's Avatar
+1 I bought what i thought was the best valvetrain setup and this crap
happens ! It makes me ******* furious
Old Jun 13, 2007 | 04:06 PM
Colin91Z's Avatar
Sent
Old Jun 13, 2007 | 04:10 PM
Colin91Z's Avatar
I must have missed that info As far as I knew, Lloyd and Bret were still using these when I bought mine. I thought I was buying the best out there
And I bet there's no way that I'll ever be able to return mine to comp or be reinbursed for the money that I spent on these all because I threw away the box already. If I had only known.
Old Jun 14, 2007 | 10:02 PM
AZ2ENVY's Avatar
So i talked to red in Comp Cams warranty claims today about the situation with the 918's . He sent me a new set of 918's and told me word for word...
"I ASSURE you that you will not have any issues with these new springs . These springs that we have on our shelves are different than the ones you have" . So my question is should i just throw on the new 918's and trust theyre good this time around ? Red said theyll have the affected batch numbers within the next couple of weeks and what happened to make them that way . I also have not got a chance to pull my valve covers yet to check my springs . BUT their batch number is 49826 which is one that other people have been having failures with . Any advice is helpful . Thanks
Old Jul 5, 2007 | 03:31 AM
AZ2ENVY's Avatar
***UPDATE***
Well i finally got time to swap out my crap 918's to PAC 1518's . Well
the second i pulled my valve covers i noticed the spring pictured below
My batch number was 49826 and i purchased these
918's in october 06' . Here is another victim to add to
the list of broken Comp Cams 918 beehives
Old Jul 5, 2007 | 06:02 PM
96capricemgr's Avatar
I have 10K on mine sofar and while I have not pulled any springs off the heads last time I was under the covers all looked go sofar.
Food for thought, how aggressive were the cams you guys with broken spring were running?
I know some people like to think they can run some truely nasty lobes on the street and that is a recipe for broken springs. What "works" and what "lasts" are not necessarily the same thing.
Old Jul 5, 2007 | 06:23 PM
wrd1972's Avatar
I have the LE 1.5 which is similar to a CC503. I busted 3 springs in 20 miles on heads built by LE. Hardly nasty lobes or nasty cam. Comp has admitted that there is a problem with the quality of the more recent batches.
