Comp 875-16 Lifters & valve lash question
Old Jul 1, 2003 | 10:23 PM
Smokn '94 Z's Avatar
Question Comp 875-16 Lifters & valve lash question
O.K. I had a couple of guys on my local camaro board tell me that the 875-16 lifters are to be set at "0" lash. Anyone hear of this?
I will contact comp tomorrow about this.
Old Jul 2, 2003 | 01:23 AM
allmotorta's Avatar
They are correct, trust me. I had mine set at 1/2 turn past zero lash not knowing they were supposed to be at just 0 lash, and it felt like I was hitting a brick wall at 6400. It just flat out quit pulling, like I hit a rev limiter. I checked everything, then posted a thread about it, and sure enough, someone told me to back off to just 1/16-1/8 past 0 lash. I did that, and it pulls to 6900 everytime now. That was exactly my problem. I have a few friends at just 0 lash with no problems, so just go anywhere from 0 lash to 1/8 turn past, and you should be fine
Edit: Read this thread....
Old Jul 2, 2003 | 08:25 AM
IROCZZ3's Avatar
Hmm, excellent info there, I did not know that!
I'm also running Comp R's that are currently at 1/2 past zero lash also. I'll try to readjust them as you describe.
Old May 31, 2004 | 09:23 PM
med_reject's Avatar
damn, guess my old school engine builder knows more than i thought. I had this argument with him and he kept insisting on zero lash. I thought this would let the lifters bleed.
Old May 31, 2004 | 10:40 PM
The Comp R's don't have as much travel as the stock lifters. If you are going to run them at 6900, then you might want them more loose. I don't rev mine that high and 1/2 turn is perfectly fine. Bottom line=one recommended setting does not fit all.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
Roadie
Feb 16, 2015 10:34 AM
jayblev95
Dec 1, 2014 06:55 AM
