Comp 850 High Energy Lifters vs Comp 875 Pro Magnums
Old Sep 15, 2006 | 06:58 PM
AlwaysCode390's Avatar
Question Comp 850 High Energy Lifters vs Comp 875 Pro Magnums
Will they both work in the LT1 in my 96z? There is only a $10 difference and the Pro Magnums say they rev higher without "pumping up". Sounds worth it to me in my LE2 setup. Thanks ---
Old Sep 16, 2006 | 04:31 PM
Re: Comp 850 High Energy Lifters vs Comp 875 Pro Magnums
I found one site that says they will work in a newer lt1, then another site that says a GEN 1 350 only, lol. Does anyone know? ---
Old Sep 16, 2006 | 05:31 PM
huskersZ's Avatar
I believe the 875's are what everyone refers to as the comp r's. The 850's are just a stock replacement deal. Apparently comp changed the design of the comp r's, and some have had problems with the new design. You need to talk to the people doing your heads and valve train and get their input as to what you should run with the setup
Old Sep 17, 2006 | 09:04 AM
cehan's Avatar
Did you bother to read Bret's sticky regarding the Comp R's (http://web.camaross.com/forums/showt...574):rolleyes:
Old Sep 17, 2006 | 11:47 AM
Thanks guys, I didnt realize those were the R's ---
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Roadie
Feb 16, 2015 10:34 AM
