Combustion Chamber size for 10:1 compression Ratio?
Old Jan 22, 2005 | 10:00 PM
Muskys SS's Avatar
On a stock LT1 what size would I have to make the combustion chamber to make the compression ratio 10:1? Or can someone tell me all the stock dimensions so I can figure it out myself.
Thanx
Old Jan 23, 2005 | 09:54 AM
OldSStroker's Avatar
Re: Combustion Chamber size for 10:1 compression Ratio?
Thanx
You might try this in LT1 Engine Tech. There are a lot more folks over there who might help you. You might also try looking up LT1 specs either in books or online. You'll probably retain a lot more of the info if you dig it our yourself rather than if someone just says 61.38 ccs.
Good luck.
Old Jan 23, 2005 | 03:02 PM
kmook's Avatar
Advanced Tech Moderator
Transferring-
Old Jan 23, 2005 | 04:10 PM
96capricemgr's Avatar
You need too consider head gasket thickness as well. The b-body has the same shortblock as the f-body but has a thinner head gasket(.029 vs. .039) and heads that are a published 64cc for the irons vs. a published 58cc for the aluminums. I say published because real world numbers will vary from this. The stock b-body motor specs out too 10:1 the f-body 10.4:1 that clear as fog?
HectorM52
Jul 30, 2017 11:46 AM
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
Timberwolf
Oct 10, 2002 05:25 PM
