Coils failing
Old Dec 2, 2004 | 06:58 PM
brendon444's Avatar
Coils failing
what causes a coil to fail ive had 4 fail in a period of 40 000 miles on my 5 th one now.
Car has 102 000 miles but just had a rebuild and cam instaled.
The last time the coil failed i replaced,
-opti-spark
-Ignition control module
-plugs+wires
-coil
thinking one of these were causing coil to go out so soon.
Do you guys have any ideas what would cause this or are the coils just that bad.
Old Dec 2, 2004 | 08:13 PM
BlownF1's Avatar
Re: Coils failing
Some details about the car, mods, and the parts you replaced would be helpful.
Old Dec 2, 2004 | 08:20 PM
brendon444's Avatar
Re: Coils failing
well this is lt1 tech so its a 1994 lt1 camaro z28 with 102 000 miles
its stock other than a comp cam like a said. I told you what i replaced.
Old Dec 2, 2004 | 08:39 PM
Pasky's Avatar
Re: Coils failing
Any electrical gremlins?
Old Dec 3, 2004 | 11:13 AM
BlownF1's Avatar
Re: Coils failing
The reason I asked is so we don't have to assume anything...and because there are differences in 93-97 LT1's especially as it relates to coils and optisparks. Filling out some info on your signature would help, and ensure you get more replies. As far as "info on the parts you replaced"...your list was fine, but I was referring to brands/place of purchase, etc. Stock GM parts, or aftermarket replacements? All these things can make a significant difference in helping you figure it out...
In any case, what brand of coil are you using? How do you know the coil is the culprit? In general the coils are not usually an issue, and not nearly as frequent as you're going through them. I've seen a number of MSD's fail...but that's just my personal opinion/experience with them.
Perhaps you've got a harness problem (which is fairly common). When you replace the coil, maybe you're disturbing it enough so that it works for awhile. Try wiggling all the related wiring while the car is running.
Old Dec 3, 2004 | 11:39 AM
Flechette613's Avatar
Re: Coils failing
I'll second the harness problem!
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
damnyankee36
Sep 9, 2015 07:06 PM
