Coil wire?
Coil wire?
Hey guys I have an OTVC wire kit that I installed 4 1/2 months ago but never changed the coil wire. I have my stock one out, but the boots on the coil wire look bigger than a regular spark plug boot. Is there anywhere I can get a pre-made coil wire? Are the male ends on the coil and opti any different than it would be for a spark plug wire? I have the wire itself but I'm not sure if the boots are any different.
Matt
Matt
Re: Coil wire?
I just switched to an OTVC setup myself. The opti end for the coil wire was the same as the other opti connections, but the coil end was just a regular spark plug boot. Also, with some kits, the coil wire coil end is labeled on the actual boot. I don't know which kit you got, but with my taylor kit from thunderracing, I just used a plug wire boot that came in one of the other bags.
Re: Coil wire?
Originally Posted by shoebox
Pretty sure that on the 96-97s, that the boot is the same on both ends (like the opti end). Earlier coils used the plug boot style.
Re: Coil wire?
I just did this actualy..
Have Taylor OTVC kit but I never changed the coil wire. Yesterday I was working on my car in that area and decided to change it since it was right there.
On the 96 and I suppose 97's both ends of the wire are the same except one is a straight boot and the other (going to the coil) is a 90 degree boot. But the terminals are the exact same as plug wires.
sleeperZ96BT
Jun 5, 2005 09:33 PM
