Coil resistance
Old 04-20-2009, 03:07 PM
mdacton's Avatar
Coil resistance
I have a coil...the primary is fine....
seconday is whats getting me.......... Checked it several time with 2 meters, I am getting 7700 and 8700 reading. I would say its weak, it still works but could it be getting weak?
My manual says spec is 5k-7k and it must be within the spec....
mdacton is offline
Old 04-20-2009, 04:35 PM
My original stock coil was about 8500 ohms. It is still in use, but now on a truck.
shoebox is offline
Old 04-20-2009, 05:33 PM
Kevin Blown 95 TA's Avatar
Ohm meter might find some gross problems and shorted turns will show up as less ohms, but without a high pot tester you dont know if the insulation in the coil is any good. Your ohm meter has a 9 volt battery and your ignition coil sees 10-40,000 volts, so how is a 9 volt battery going to tell you if your insulation is bad under high voltage potential?
Another thing is heat. These things often fail under heat stress moving the hair-thin wires around after they break - Sometimes it is making contact, then it doesnt. You can simulate heat stress with a heat gun if you want to look at it on a bench tester, it might take a while - just don't melt the thing.
Kevin Blown 95 TA is offline
Old 04-20-2009, 06:16 PM
mdacton's Avatar
Oh well, I just got this http://store.summitracing.com/partde...5&autoview=sku
I'm just going to use it from now on
mdacton is offline
Old 04-20-2009, 06:21 PM
Is that for a CDI?
PopoFormula
10-12-2015 04:19 PM
68camaroboltz
10-05-2015 01:46 PM
greenzee28
09-25-2015 04:29 PM
jackpawt883
09-10-2015 08:53 PM
Quick Reply: Coil resistance
