coil??fit coil wire????? how???help!
Old Apr 8, 2004 | 06:25 PM
cridom's Avatar
Angry coil??fit coil wire????? how???help!
help for some reason the coil wire from msd doesnt fit the msd coil.
the end is like the same as the opti end. should i just put some strenth and make it fit? it seems too small to fit.
thanks.
also are msd better than splitfire wires?
Old Apr 8, 2004 | 06:40 PM
Did you get a new set of MSD wires? Sounds like you are trying to put the 96-97 style coil wire on your 94. They usually put 2 coil wires in the set-one for each style. See if you have another coil wire.
Old Apr 8, 2004 | 06:49 PM
cndctrdj's Avatar
my set of msd wires thier was one that wasn't right i had to send it back and get the right one the next day
Old Apr 8, 2004 | 07:18 PM
cridom's Avatar
thanks i did get 2 cables for the coil. also what are those rings that come with it? are they for labeling the wires?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
kandied91z
Aug 6, 2002 01:18 AM
