Coil
Old Jan 20, 2010 | 11:19 AM
moparman's Avatar
Coil
Car is a '96 Formula. I replaced the coil about 10 days ago because it was arcing, and of course the engine was misfiring. Replaced it with an AC/Delco oem, and the new one is now beginning to arc as well. I suppose the new coil could be bad, but is there something that can cause a coil to go bad?
Old Jan 20, 2010 | 11:23 AM
RamAir95TA's Avatar
Where is the arch coming from? It's more likely that the coil wire is split or cracked somewhere.
Old Jan 20, 2010 | 11:31 AM
moparman's Avatar
The arc was/is coming from the coil. Coil wire was first suspect. Replaced it as well.
Old Jan 21, 2010 | 03:58 PM
moparman's Avatar
Is it possible for the ICM to arc?
Old Jan 21, 2010 | 05:07 PM
Mikes 1994 z28's Avatar
I had a similar problem with MSD coils. I kept thinking that I just got a bad batch of MSD coils (I went threw 3 returns) after noticing the coil arcing. I checked everything... plugs, wires you name it. Eventually I put the stock coil back in and took it to a dealership, which I never do. They discovered that one of my spark plugs was faulty and that it was creating a lot of resistance which caused the coil to arc. This surprised me since I had replaced the plugs around 5000 miles ago and my opti around 7500. Plus, my engine for the most part was running clean. I guess I got a bad one out of the bunch. Strange, I know, but it made a world of difference and I never had the problem again.
Also, make sure you didnt us a lot of anti-seize. You only need a small dab. Using too much might make the path to ground much less conductive.
Old Jan 22, 2010 | 12:09 AM
Fatdog2's Avatar
Sounds like the coil is looking for a ground.Might check the heat shields around the plugs,I dunno.Hope this helps.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
