Clutch Question
Old Oct 7, 2003 | 01:30 PM
Laymaster's Avatar
Clutch Question
About...a year and a half ago I replaced my clutch with a McLeod Dual Performance clutch. A bunch of people told me I didn't need to resurface the flywheel and I kinda skipped that step. The car vibrated a little, most notably in reverse. It may be the reason why my transmission mount (1LE) bit the dust after less than one year.
I put in a poly trans mount and now it's almost impossible to go in reverse...well it's possible, it works fine, it just rattles the car to death (and scares people at 50 yards).
I'm probably going to be doing a clutch job soon, most notably turning the flywheel. Mods are in sig. Current clutch has 30,000 miles on it. Any suggestions on what I should do, what clutch I should get, and also if I do need a clutch, pressure plate, and throwout bearing? I'm probably going to go with a SLP Disc, Plate, etc, but I'm open to suggestions.
Old Oct 7, 2003 | 01:43 PM
Fastbird93's Avatar
Well, I don't believe you want to turn a flywheel more than once. You could run into problems after that. The McLeod is a good setup IMHO.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
