Clutch Problems HELP!!!!!!
Old Aug 4, 2003 | 02:29 PM
  #16
PatriotTA's Avatar
Originally posted by kgkern01
How bad is that clutch in everyday driving? Would downshifting/engine braking help to cause this?
I'm sure the stage 4 isn't the best for every day driving. You have a basically stock car, you should get a stage 2. The most important thing is figuring out why the hell this keeps happening. An unsprung disc will not break springs (duh) but it could break something else by removing the spring as the weakest link. I would suggest a stage 2 and have it installed at a different shop, or do it yourself. If you do it yourself, it will always be right. The shop could have side-loaded the disc when it was being installed by not tightening the pressure plate bolts properly, or they might not have properly repaired the trans. I'd talk to them.
Old Aug 4, 2003 | 02:34 PM
  #17
HungryT/A's Avatar
Sorry, I'm posting it here, too:
What do you think, would a Stage II Kevlar hold up on a bolt on T/A with a 100-shot and ET Streets?
Thanks guys!
Old Aug 4, 2003 | 02:36 PM
  #18
Randomsoleil's Avatar
Thanks guys!
It will hold up to the bolt ons but not nescesary the 100 shot
Old Aug 4, 2003 | 07:42 PM
  #19
gb95zconv's Avatar
My stage 4 drives fine......it is grabby but thats what it is suppose to Hardest thing to get use to is that ingages very high.
Old Aug 4, 2003 | 09:00 PM
  #20
kgkern01's Avatar
As far as a daily driver, the Stage 3 is NO problem with driving around, it is a little grabby, but nothing you won't get used to. I actually enjoyed mine, till the springs blew out of course.
Old Aug 5, 2003 | 02:54 AM
  #21
HungryT/A's Avatar
Yeah, I heard about Stage III clutches shredding into pieces in some people's cars...
How did it happen? Clutch dropped at 6000 RPM ?
Old Aug 6, 2003 | 09:52 PM
  #22
kgkern01's Avatar
No clutch drops at all on this clutch, some nice hard shifts, and downshifts but thats it.
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
