clutch noise when wet out
Old Apr 14, 2003 | 10:05 AM
Lowend's Avatar
I have a 95 M6 Firebird Forumula. I have noticed that the clutch makes a pretty good amount of noise, but really only when its been raining.
The clutch is about 2 months old (Borg Warner) and I replaced the slave cyl at the same time.
Is this a common problem? Ideas?
Old Apr 14, 2003 | 10:58 AM
fbird95's Avatar
The pedal itslef, or the clutch? Clutch sqeak is common with the hydraulic set up especially when its damp. The stock set ups are know for making all sorts of noises, some consistant and some erratic. I hear some aftermarket clutches are worse, noise wise.
Old Apr 14, 2003 | 08:46 PM
Lowend's Avatar
Its not the pedal...
If I hold the pedal in you can hear the clutch whiring.
Its just a little disturbing
Old Apr 14, 2003 | 09:37 PM
fbird95's Avatar
Lowend, I got the same S**T going on today. It is disturbing. Does yours go away when you either rev the engine or shift into gear? Send me a personal message if you figure out what it is.
Greg88
Aug 24, 2015 07:59 AM
karpetcm
Aug 14, 2015 03:02 PM
colts0455
13
Aug 7, 2015 09:15 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 7, 2015 07:19 PM
