"Clunking" noise occasionally on 1-2 shift @ 3/4 throttle
Old Jun 15, 2004 | 07:38 AM
pu12en12g's Avatar
Ok.. symptoms:
- 95 Z28 Convertible, stock tranny, 109,000 miles (I think.. it's around there)
- Clunking noise SEEMING to come from directly under the armrest, it is pretty noticable, but only on the 1-2 shift @ more than 1/2 throttle. If I am just cruising, then NO clunking noise and perfect shifts.
What do you guys think ? Could it be anything other than tranny rebuild time ?
Old Jun 15, 2004 | 07:47 AM
simple's Avatar
you did check the trans mount?
very very common with A4 cars and most noticeable during a shift at more the ~1/2 throttle
Old Jun 15, 2004 | 07:56 AM
pu12en12g's Avatar
No I haven't checked anything yet. It just started doing this. If it's just the tranny mount that will kick ***.
Old Jun 15, 2004 | 08:26 AM
teke184's Avatar
torque arm mount is worth checking out too...pretty easy to check if you are checking the trans mount.
Old Jun 16, 2004 | 02:35 AM
tv559's Avatar
Same thing was happening to my 1997 A4 it feels like a hard hit from under the shifter. Just had my Trans Mount replaced with a energy Trans mount.
Old Jun 16, 2004 | 10:23 AM
Zigroid's Avatar
its most likely a transmission mount, I went through 3 stock type ones until I switched to an energy suspension mount. but be warned, the polyurethane mount will transmit vibrations considerably more than the rubber ones.
Old Jun 16, 2004 | 11:53 AM
phrozen's Avatar
I doubt it's your trans mount. When mine went out it was banging from a dig when i accelerated hard, at only made a banging noise when i accelerated hard.
Old Jun 16, 2004 | 12:23 PM
Joe Bellman's Avatar
Re: "Clunking" noise occasionally on 1-2 shift @ 3/4 throttle
Originally posted by pu12en12g
- Clunking noise SEEMING to come from directly under the armrest, it is pretty noticable, but only on the 1-2 shift @ more than 1/2 throttle. If I am just cruising, then NO clunking noise and perfect shifts.(
Transmission mount, use a pri bar to lift up on the transmission to see if the mount is torn.
armedtrigger
Feb 24, 2015 08:30 PM
baron4406
Sep 15, 2002 07:42 PM
RichardZ SS
Aug 3, 2002 12:26 PM
