cloyes double roller
Old Dec 27, 2007 | 11:19 AM
asia517's Avatar
I am rebuilding my 94 LT1 and am using a cloyes double roller timing chain, I need to know which grove and timing mark to use?, there are 3 and i have been told that there is one specific one for my motor.
Old Dec 27, 2007 | 11:53 AM
Alex94TAGT's Avatar
Find #1 TDC, and install the crank gear so that the 'circle' mark is at 12:00. Simple enough.
[Edit] -- Don't forget, you'll likely need to clearance the timing cover as well.
Old Dec 27, 2007 | 11:56 AM
Stl94LT1's Avatar
One is straight up, and the others are + or - 4*
Old Dec 27, 2007 | 11:59 AM
asia517's Avatar
thanks, I just looked up the directions on there website should I go + or - 4* or stock?
Old Dec 27, 2007 | 12:02 PM
jsetzer's Avatar
stock
could you link those? I would like to see them.
Old Dec 27, 2007 | 12:03 PM
Alex94TAGT's Avatar
Stock. You don't want to advance or retard the timing here, as it will alter your valve, ignition, and fuel timing. We can handle such things with different camshaft grinds and PCM programming.
Again, use the circle. Not the triangle or square or whatever.
e:f,b
Old Dec 27, 2007 | 12:23 PM
asia517's Avatar
well I have
Engine Displacement - 355
Cam Info - COMP CAMS 07-503-8 or LT1 XR276HR-12
Intake/Exhaust Lift - .503/.510
Intake/Exhaust Duration - 224/230
LSA - 112.0
with this cam setup should I still use the stock key on the timing set
Old Dec 27, 2007 | 12:27 PM
asia517's Avatar
here is the link http://www.cloyes.com/Portals/10/Tec...structions.pdf
Stl94LT1's Avatar
Yes.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Bxlt1
Sep 10, 2015 08:16 AM
