Cleaning MAF
Old Sep 16, 2003 | 09:44 PM
ead94z28's Avatar
Question Cleaning MAF
I am planning on cleaning my MAF sensor. I see that there are silver horizontal bars in there with tiny wires that connect the bars. I read about using electronic cleaning spray or something like gummout, and a q-tip. Also, which parts inside do I gently rub with the q-tip?
I have also read that you need to remove some kind of screen. I do not have a screen in mine. Is this part missing and should i be concerned?
94z28
Old Sep 16, 2003 | 10:19 PM
jasons93z's Avatar
It should have a screen, so it sounds like the previous owner removed it. Dont be concerned. I cleaned mine with an electrical cleaner and a q-tip. I just swabbed everything, but be VERY gentle.
PoorMan's Avatar
You can clean the vertical bars with electrical cleaner and q-tips. Do not touch the wires with q-tips cause they break off pretty easy. I don't see the need for it unless they are caked up though.
Jeff D.
Old Sep 17, 2003 | 08:56 AM
stereomandan's Avatar
I had to clean the sensors(between the vertical bars) with the Q-tip. I was VERY gentle though. It doesn't take much to remove the deposits.
Car ran super smooth after the cleaning.
Dan
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
