Cleaning the IAC
Old Sep 14, 2003 | 11:50 PM
  #16
Originally posted by 96Z28SilverStreak
I took mine apart and cleaned it as described above. After I put it back together. Now when I crank my car it idles up to about 2k then down to about 1200 rpms. I replaced my Iac and put new gaskets on eveything. I am still having this problem.
Any ideas?
Did you pull/push on the pintle and change it's location? That would cause a lack of position synchronization with the pcm (it can also damage it). You might try resetting it with this procedure, though it does work for every situation. Also, if you have reset the pcm, it may not have had time to settle in the idle speed, yet.
IAC reset
-Depress accelerator slightly
-Start engine, then release accelerator pedal, run engine for 5 seconds
-Turn ignition "OFF" for ten seconds
-Restart engine and check for proper idle operation
Old Sep 29, 2003 | 03:38 PM
  #17
pvkn1ght's Avatar
how to avoid damaging the pintle
My newly acquired '95 Trans Am has a high idle when I start it approx 5-10min after driving it (engine is still warm), which dies down after maybe 10-15secs.
I'm planning to clean the TB and IAC this weekend but am worried that I'll damage the 'pintle' (to clarify, is this the part attached to the spring??) how can I do this without making my idle worse? I've cleaned my TB on my 3rd gen before, but only while it was on the car, I've heard this can cause the carbon buildup to seep into and plug the IAC?
all help appreciated
Brian
Old Oct 2, 2003 | 12:06 AM
  #18
pvkn1ght's Avatar
ttt
having the same issue: 2000rpms for approx 10secs when starting the engine shortly after turning it off... the idles then drop to ~1200. could someone elaborate on what part of the tb or iac may be causing this? i have not yet unbolted or cleaned my tb or iac, i do plan to this weekend and need to know where to be xtra careful
thanks
brian
Old Oct 2, 2003 | 10:05 PM
  #19
pvkn1ght's Avatar
ttt
any help please? i've been reading about people having more problems than prior to cleaning due to altering the pintle position - i already have a high-rev start-up as described above, is it still a good idea to clean the tb and iac?
Old Oct 3, 2003 | 02:20 AM
  #20
TobyZ28's Avatar
Originally posted by pvkn1ght
ttt
My guess is your IAC is busted already if its high revving so it doesnt hurt to try.
Old Oct 4, 2003 | 09:14 PM
  #21
pvkn1ght's Avatar
question: when removing the tb from the plenum, is it totally safe to remove the two rubber hoses on the passenger side of the tb when the engine is off? is there going to be any coolant coming out?
thanks - brian
Old Oct 4, 2003 | 10:14 PM
  #22
thanks - brian
On the upper RH side of the TB, there is a small vacuum hose that goes to the EVAP solenoid and a larger vent hose that goes to the valve cover. No coolant is going to be in those hoses. The only coolant will be in the hoses that go to the bottom of the TB (unless you have already done the TB coolant bypass).
Old Oct 12, 2003 | 05:40 PM
  #23
sean1997ws6's Avatar
Having the same problem silver. need some help
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
tdigger9899
Sep 7, 2015 10:56 AM
