Cleaning/fixing IAC?
I just tried cleaning an intermittant IAC that was sitting dormant in a transplant motor for over a year. no luck. I used sea foam, wd-40, carb and choke cleaner, etc.
The Throttle body is held on with 4 10mm bolts, the IAC is on the bottom, held on by 2 T15 torx bolts. You need to replace the gasket on the TB, IAC has rubber o-ring. If you do decide to pull it apart to clean everything, make sure you oil the IAC with clean motor oil. I just dipped my finger in a bottle and wiped it over the IAC valve. I cleaned the bore out w/ a nut driver w/ a rag wrapped around it and soaked w/ sea foam.
I got a new one from NAPA for wholesale $57, walk in price is $107.
Good luck.
Good luck.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
