Cleaning the block for head swap?
Old Mar 15, 2008 | 12:18 PM
95zsean's Avatar
What have you guys used to clean the block before you reinstall your heads. I'm worried about getting stuff in the engine and hurting the rings or bearings. Thanks.
Old Mar 15, 2008 | 12:25 PM
SS RRR's Avatar
Put every piston at TDC before cleaning the general area, have a shop vac handy, apply brake cleaner to block/pistons and clean with a steal brush. Works fabulously.
Old Mar 15, 2008 | 12:46 PM
maverickmk's Avatar
the shop vac will be invaluable, definitely a must
Old Mar 15, 2008 | 01:43 PM
95zsean's Avatar
I read in GMHTP that they used a 3M Roloc Bristle 80 grit Disc instead of a wire wheel. Less chance if getting metal in the engine and causing damage.
The shop vac is a Great Idea, instead of blowing the stuff everywhere!!!!!!
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
