Cleaning the block
Old Oct 21, 2004 | 02:08 PM
Euclid's Avatar
Cleaning the block
I've got my motor down to the block, and boy is this thing nasty!
Do you guys have any reccomendations as to what kind of products or techniques I could use to clean all the gunk, gaskets, oil, etc off of this sucka?
Thanks!
Old Oct 21, 2004 | 03:04 PM
BlownF1's Avatar
Re: Cleaning the block
Are you planning to have it rebuild or ? If so, I'd just let them clean it up, otherwise you'll remove all the oil that is preventing it from rusting.
Old Oct 21, 2004 | 03:07 PM
Euclid's Avatar
I'm just doing a heads cam swap and wanted to clean her up before I put it back together.
Old Oct 21, 2004 | 04:14 PM
amean94ta's Avatar
engine bright but use masking tape on area's you dont want water and spray after with wd-40 on all bare metal
Old Oct 21, 2004 | 04:17 PM
WS Sick's Avatar
Oven cleaner, and then finish with warm soapy water, dry with air (turn over on stand several times to get all the water out). Now oil the inside and cylinders and tape and paint the outside.
Old Oct 21, 2004 | 05:39 PM
TobyZ28's Avatar
For general degreasing i use pinesol Works awsome on really greased up parts.
Old Oct 21, 2004 | 05:56 PM
BlownF1's Avatar
Ahh, I see! I just got done tearing my motor down to the block too...a bit different definition though, my old block is sitting next to the car! For the rest of the stuff that was in the car, I bought some engine degreaser at the local parts store that was citrus based...worked great.
Old Oct 22, 2004 | 10:43 AM
Euclid's Avatar
So just spray everything down and hose it off?
Water shouldn't hurt anything in there, right? As long as I plug the holes in the lifter valley and sop up the water out of the cylinders?
Should I use the same products to clean up the heads?
Old Oct 22, 2004 | 11:17 AM
WS Sick's Avatar
Ahh , I misunderstood you,I thopught the engine was out of the car. Don't use the oven cleaner if it is in the car, it eats rubber and other plastics.
Old Oct 22, 2004 | 11:51 AM
BlownF1's Avatar
Uhh...NO! I sprayed it on a rag and wiped...used lots of rags, but it goes pretty quick. I wouldn't just hose off an open motor, no matter how good you think you've got it sealed up.
Old Oct 22, 2004 | 08:34 PM
Euclid's Avatar
I'm worried about products dripping into the oil pan... Should I be?
Old Oct 24, 2004 | 01:54 AM
BlownF1's Avatar
Yeah...you don't want ANY foreign matter inside motor. If it were mine I'd either be real careful and apply a cleaner to a rag and just spot clean, or wait until it's buttoned back up.
Old Oct 24, 2004 | 02:25 AM
Euclid's Avatar
Fuggit, my friend tore the oil pan gasket when he pulled off the timing cover, I'll just pull the oil pan out, replace the gasket, the oil pump, everything. Git er done right.
What's the best way to clean off the pistons? They look like fricken chimneys, they're so gunked up.
Old Oct 24, 2004 | 04:54 PM
amean94ta's Avatar
dont worry about the piston tops they wont hurt anything. but that tells me you need head work if its caked on there
Old Oct 24, 2004 | 06:18 PM
Euclid's Avatar
I think I'll just dab a rag in seafoam and scrub everything down... does that sound like a good idea?
Why do I need head work?
