checking piston to valve clearance
Old May 19, 2003 | 09:49 PM
joefreeland's Avatar
I know how to do it but have a few questions. How do i disasemble the lifter so that I can shim the pluger up to use it for checking. Also do you need to use a check spring instead of a regular valve spring?
Brad
Old May 20, 2003 | 08:06 AM
Some lifters don't come apart so easily. Usually there is a retaining clip that can be removed when the lifter is compressed a little. You could then figure out how to make it solid, but it might be easier to just buy one solid lifter, instead.
A check spring would sure make it easier to deal with during checking.
Old May 21, 2003 | 12:35 AM
Are the solid roller lifters the same height as the hydraulic rollers?
brad
Old May 21, 2003 | 07:51 AM
brad
If they are deigned to use stock length pushrods, I would think so. That question was also in my mind.
Old May 21, 2003 | 08:01 AM
Dave C. '97 Z28's Avatar
It doesn't matter the height of the lifter if you're just checking piston to valve clearance because you're going to set the rocker arm to 0 lash anyway.
What I did was just disassemble a lifter and put a 1/4" drive socket in there. Then I stuck the pushrod in and it sat on the socket in the 1/4" drive hole. adjust the rocker to 0 lash and there you go. This is good because you can also check your valve spring coil-coil clearance and your retainer to stem-seal clearance as well.
-Dave C. '97 Z28
PS: Remember to install the lifter guide on there while you're checking so your roller doesn't turn sideways and damage your cam lobe.
Old May 21, 2003 | 08:20 AM
Re: >>
Good point.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
