check PCM
Originally posted by southern78
I was thinking I could maybe wire up a fuse link with a power source and test. There has to be a way to build a bench tester for it.
Oh well just thinking.
Shoebox, What would you say the problem is. I have power to starter and everything but nothing happens when i turn the key except starter engages but other than that no fuel pump or anything. I have juice every though. Checked all pins going to pcm that require it and checked grounds also. I also check fuel pump by jumping to it and giving it some power which turned it on. I have checked all fuses, relays, and power/grounds leading to pcm. Checked for any loose connections on everything. Replaced fuses just to ensure one wasn't partially bad (Though I tested them all with a tester).
Sorry about the delay in response on my behalf.
I checked everything but the spark. That being said I assumed it was the PCM because I tried several times to connect using my Lt1 edit and other software but never got any connection (only keep trying to connect in the software). Seems the PCM just wasn't powered on. Yes, I had the ignition key in and on. Goodness knows I probably have a voodoo cursed pcm (lol). I tried dancing around the truck to scare off evil spirits also but to no preveal.
No security (VATS) on it. Disabled in PCM. 95z camaro in s10 blazer (88). No lights in dash as far security goes. Interior lights and dash lights works. Everything comes except pcm.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
