Check out these Roller Rockers....
Old Mar 31, 2006 | 05:10 PM
  #16
hotrod18_69's Avatar
Re: Check out these Roller Rockers....
Originally Posted by BUBBA
I admit I don't know whether they will work or not, but remember that your top end is really important and needs to be stable and geometrically balanced because it only takes a start up and and a broken keeper to swallow a valve. JMHO
Yeah i know.. Good point.. I have taken that into consideration..
Old Mar 31, 2006 | 10:35 PM
  #17
97FormulaWS-6's Avatar
so... did you buy the first ones or the ones I posted?
If you bought the first ones, good luck; the reason they don't fit is because of the center-bolts for the valve covers, the rockers are too wide, and no matter how much clearancing you do, you can't mount the VC's properly.
The ones I posted are the ones needed for a centerbolt style VC, and still require trimming of some internal tabs of the VC. They also require the Pushrods, and guideplates because they are NSA. They are narrower than the 53-87 rockers to clearance the bolt comming through inbetween them; whereas the 53-87 SBC's had edge-bolt valve covers and the rockers could be right next to each other.
Not all parts for a 350 chevy are universal, the LTx motors are unique and have many things that are not interchangeable.
Old Mar 31, 2006 | 10:41 PM
  #18
crAzy95z28's Avatar
why not just get some LT4 roller rockers 1.6's?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
