Check out the size of this cam for the LT1
Old Apr 26, 2006 | 01:28 PM
MAJESTIC's Avatar
Comp cams makes a 220/230 dur.at .050 and 510/510 lift.
I'm looking for a cam with good street manners and one that does not run pig rich. I want a good cam over stock. I dont know what cam this is cause I
don't understand how to read cams. i just want a good street driver with manners. I'm not building a strip or race car.
This will go on a stock lt1 with full boltons, and maybe 1.6 magnum rollers.
Old Apr 26, 2006 | 01:44 PM
BlackScreaminMachine's Avatar
Re: Check out the size of this cam for the LT1
looks good, looks emission passable but is the lift figured with a 1.5 ratio or 1.6??
Old Apr 26, 2006 | 01:52 PM
seawolf06's Avatar
That lift is most likely with 1.5 rockers, so the lift with some 1.6 RR would be 544/544. That's a good cam to start with. Do a search on here and you'll find plenty of ideas on what's good for just the street, street/strip, what has good lope, and what's good for emissions. The search button is your friend. Also, check this out:
LT1 cam specs
Although, the rpm ranges aren't very accurate for max performance, they're a good range for the cam. I'd reccommend CC503, CC305, or GM846. Good luck.
Old Apr 26, 2006 | 01:56 PM
neil350's Avatar
The 220/2230/114 is the Cc305
Old Apr 26, 2006 | 02:00 PM
MAJESTIC's Avatar
What if it was ordered in a 112 LSA
and what is the CC305 with a 114 good for??
Is it a good sreet cam??
Old Apr 26, 2006 | 02:29 PM
neil350's Avatar
Been around for years, couple other cams already set up on a 112, Hot Cam, X.e 224/230 and a few others. CC305 has a really nice idle, you can hear it but it isnt really lumpy or any thing. With tunning it will pass smog, real mild street cam.
Old Apr 26, 2006 | 02:38 PM
Javier97Z28's Avatar
Moderator
I wouldn't use a single pattern cam on an LT1 with stock unported heads. You should have the split in there to make up for the weak exhaust side.
Old Apr 26, 2006 | 04:29 PM
marshall93z's Avatar
It's not a single pattern.
Old Apr 26, 2006 | 06:56 PM
Moderator
jesus i'm blind.. for some reason that looked like 230/230 to me...
brainfart, never mind
Old Apr 27, 2006 | 07:22 PM
MAJESTIC's Avatar
So If I run the CC305 will I have the pig rich smelling problems,
or is that taken car of in the tune??
Old Apr 27, 2006 | 07:46 PM
neil350's Avatar
Tune and cats and it wont smell, no cats its gonna smell like no cats.
Brandon Wittmer
Dec 20, 2014 09:51 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
