Check out this SCAT Stroker Kit
Well we were assuming you knew a little bit about what you were doing. LE3 383 motor will make 425ish to the wheels meaning over 500ish at the crank. So 500ish + 150ish = More than 600ish.
I find it amusing that you don't even know how much power you'll be making
-Dustin-
-Dustin-
But regardless, your right. I forgot to factor in that's RWHP. I'm just NOW getting this setup idea together so I'm going to overlook many obvious details.
Well damn, that's going to add to cost. Using KB Forged opposed to JE will cut cost but is it a worthwhile way to do so ? Somebody said KB's are good quality so I'd assume that would be fine with the scat H beam rods/scat forged crank or even eagle.
Listen to people with experience here, they've spent years doing this. Your the one saying the cast crank will work, but then you say you dont want to cut corners. It just seems like you've got the money but not the knowledge. You'll need both to get things to get everything to work together and have a decent car. Otherwise you'll be here a week after the motor is in asking "Why am I bending pushrods" or "Low on power, only dyno'd 354rwhp?
Just trying to keep you from tossing money out the window.
Then again doing some research wouldnt hurt either, this has been talked over 100's of times.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
Hence why I turn here before I would ANY reputable machine shop. People here KNOW what's going on. What do you honestly think though ? Have you run across places that sale a TOTAL package for a good price ?
one thing i have learned first hand is you can buy the best parts but if you don't have a GOOD engine builder who does high performance engines you will have problems when reving high. a lot of people including me have had engine failure due to bad ,machinig,assembly, balance etc, then want to blame the parts. the new builder i am dealing with has made me put some thought into what i want and how i use my car. he has made me think more about drivability and torque which make a nice street car.
just my $.02
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
