Check out my parts list, let me know what you think about the combination!
Old Oct 16, 2004 | 04:12 PM
BlackLT1_TX's Avatar
Block- Fresh std bore, stock pistons, speedpro rings, fresh hone, polished crank and resized rod caps. All new bearings.
Heads- Lunati 73943 springs, spec sheet says good to .630, gmpp 1.6 r/r, milled .060, new valve job and bowl port work
Valve Train- cc306, Cloyes double roller, arp hardend rocker studs, stock 95 pushrods and lifters.
Extras- jet hot long tubes, custom 3inch y pipe, csi elect. waterpump, and probably a 3400stall.
What do you guys think, any conflicting parts? Let me know so when I put it together I dont have too many suprizes.
-James
Old Oct 17, 2004 | 10:34 PM
Re: Check out my parts list, let me know what you think about the combination!
ttt, and by the way, looking more toward the gm847
Old Oct 17, 2004 | 10:36 PM
turbo_Z's Avatar
spending a lot of money there.. may as well go with some decent lifters and pushrods. Id say comp Rs or the 875 series lifter and some chromoly/hardened pushrods.
Old Oct 17, 2004 | 10:44 PM
rpm4lalo's Avatar
So are you going to port the heads?
Why are you going to have the heads milled .060???
When I had my heads milled, I went with .010 I believe. That way I could go .020 the next time they came off and .030 the last time. I didn't want to ever have to go more than .030..............Peace, Lalo
Old Oct 17, 2004 | 11:05 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
You are most likely going to need lifters
Old Oct 17, 2004 | 11:17 PM
Okay, how about this.
The K-800's, can I use a stock retainer and locks?
Comp Pushrods
Comp R lifters
1.5 NSA R/R's
GM Guideplates
GM847
milling only the required amount to plain heads
some minor bowl work on the heads.
what do you think, please help me with suggestions.
Old Oct 19, 2004 | 10:58 AM
TransAmGT94's Avatar
Sounds better you will need the lifters and rods but why 1.5 rockers why not move up to 1.6's and you know nsa rockers need guide plates
Sorry missed the guide plates in your last post
Old Oct 19, 2004 | 01:30 PM
ScreamnChicken's Avatar
definately get the lifters, rods and 1.6 rockers. Sounds like you want to go pretty crazy with this. I would go with the 847 over the 306. The 306 feels pretty tame to me:shrugs:
Old Oct 19, 2004 | 10:08 PM
rpm4lalo's Avatar
Old Oct 19, 2004 | 10:27 PM
chy20k1's Avatar
buy arp bolts/studs for the rods and mains
Old Oct 19, 2004 | 11:38 PM
trans9_5am's Avatar
You just said Comp pushrods too. Make sure they are the one piece chromoly ones.
Brandon
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
