Check This Out
Old Mar 14, 2004 | 06:43 PM
Schearer225's Avatar
Cool Check This Out
Hey just got my rim's on today, and took some pic's and updated my cardomain site! check it out! http://members.cardomain.com/schearer225
Old Mar 14, 2004 | 06:49 PM
Pandamonkey's Avatar
Wicked Awsome.
I saw that you already posted in the appearance section - so this thread likely won't last long here - seeing as how it's not performance LT1 tech related.
Old Mar 14, 2004 | 06:56 PM
lol, yah i know. i am just trying to show everyone!!! lol
Old Mar 14, 2004 | 07:06 PM
Loadre's Avatar
um, are your rear tires mounted backwards?
http://images.cardomain.com/member_i.../494246_21.jpg
Old Mar 14, 2004 | 07:09 PM
Tair's Avatar
They look pretty nice.
Old Mar 14, 2004 | 07:25 PM
Brent94Z's Avatar
Super Moderator
Ok, Schearer225, shame on you for knowing you weren't really supposed to post this here but did anyway Since you already have one of these in the Appearance Section (where it belongs!) I was just going to close this one. Then I noticed the reply by Loadre. Your tires are mounted backwards, bud!!! So, the goods news is that now there is some technical aspect to this thread (if it sparks a discussion about the dangers/considerations of mounting directional tires the wrong way!) so I'll leave it at least for now
Old Mar 14, 2004 | 07:33 PM
My tires are mounted backward's? is that really bad. how can you tell? the rear tires size is 275/40ZR17 Y98. (directly of the reciept) What should i do?
Old Mar 14, 2004 | 07:35 PM
Loadre's Avatar
go look on the wall of the tire. it should say direction and have an arrow pointing to the direction of rotation.
Old Mar 14, 2004 | 07:36 PM
jchevy's Avatar
Look at the sidewall of the tire, it will have a arrow indicating the direction they are supposed to rotate, they might also say right or left. Go back to the shop that put them on and tell them to fix it.
Looking at other pictures it looks like both rears are backwards, so just take the two rears and swap them, put the right rear on the left rear and left rear on the right rear. Check the fronts too.
Old Mar 14, 2004 | 07:39 PM
Anderson's Avatar
You might have to just swap the tires from side to side, unless the others are facing the right way.
Old Mar 14, 2004 | 07:42 PM
Loadre's Avatar
If the shop put them on that way then you might be able to get some compensation out of it.
Old Mar 14, 2004 | 07:45 PM
Brent94Z's Avatar
Super Moderator
Will he be so lucky? Let us know, Schearer225
Old Mar 14, 2004 | 07:50 PM
alrihgt, i just went out and check the tires.... i am a idiot. when i put the rim's on, ( i got a place to mount the tires on, since i wasn't sure if i would have to grind anything cuz of the clearance issue. and mounted the rim's my self) i didn't take notice of the rotation, and the rotation's are wrong . SO i got to siwthc all the tires around. . but about the tires being mounted backwards....... the writing is on the outside, does that matter, hwo can i tell if they are mounted backward's?
Old Mar 14, 2004 | 07:56 PM
Anderson's Avatar
let just put it this way. The arrows on the sidewall should be pointing int he direction of forward rotation. There is no Inside/Outside part of the tire (on your tires atleast). Its already determined that all you have to do is swap the 2 rears from one side to the other.
You will notice that hte Thread patern has arrow shaped grooves. If you are looking at the top of the tire, those "arrow" grooves should be pointing towards the front of the car. Check the fronts and see how those are.
Old Mar 14, 2004 | 08:04 PM
ok, i will swithc the sides tommorow..... thanks for noticing that in ym pic, i woudl have never even noticed . you guys notice everything!!!
