check engine light comes on when cooling fans come on?
Old Jan 24, 2006 | 09:59 AM
Critter's Avatar
comes on when fans for radiator turn on. goes off when fans turn off at a standstill.... but comes back on when i got over 1800 rpm?
i think it could be a combination of two things?
1. electrical?
2. o2's
Old Jan 24, 2006 | 10:03 AM
Stoopalini's Avatar
Re: check engine light comes on when cooling fans come on?
It's actually the other way around. Your fans are coming on because a code is being tripped. It's a fail-safe the computer uses for certain codes.
You really need to have the PCM scanned and pull the code out of it before you can even begin to guess what is causing it.
Thomas.
Old Jan 24, 2006 | 10:13 AM
Critter's Avatar
don't have acess to a scanner? autozone? how much am i looking at to scan? i know its like 40 isn't it?
Old Jan 24, 2006 | 10:49 AM
Pullngz's Avatar
Before you spend money, try checking your fuses. Specifically your air pump fuse located under the hood. Might not be it buy it's worth a shot.
Mike
Old Jan 24, 2006 | 11:05 AM
Stoopalini's Avatar
What year is your car?
Autozone will scan an OBD-II car ('96+) for free. If you have OBD-I ('93-'95), you can purchase a cable and download free software to do it yourself.
Just do a search on the board for OBD-I and freescan.
Thomas.
Old Jan 24, 2006 | 11:43 AM
Critter's Avatar
car is a 94. how much is a cable and how much am i looking at spending
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
