check engine light
Old Feb 18, 2004 | 06:50 PM
cndctrdj's Avatar
check engine light
ive been seeing this check engine light on and off now for about 6 months. when it comes on my car stumbles like its misfireing without the misfire. its usually when im below 2k rpm's. then it goes off and i get all my power back. well it started to stay on for long times. i brought it to the shop and they said it was the egr valve. so i got it replaced. well the problem is still thier. and the check engine light is still on. before i go to the shop and spend more money on stuff i don't need. does anyone have any ideas whats wrong with my car
Old Feb 18, 2004 | 06:53 PM
camaroguyo's Avatar
what code is it tellin u??( if u dont know a auto parts store should be able to plug it in for u)
Old Feb 18, 2004 | 08:26 PM
cndctrdj's Avatar
an autoparts store like autozone ?
Old Feb 18, 2004 | 08:27 PM
camaroguyo's Avatar
yep, thats where i go, one of the only places that will do it for free.
Old Feb 18, 2004 | 11:43 PM
Most AutoZones will have a problem with the 1995 LT1. They see that it has an OBD-II ALDL connector, and hook up their OBD-II scanner. Of course it won't "connect" with the 95's OBD-I computer, so they get all confused. You need to find a shop that A) is willing to scan an OBD-I computer, and B) has the proper connector for the 1995.
Old Feb 19, 2004 | 07:20 PM
cndctrdj's Avatar
monday i will be bringing it to the shop to scan. thats about my only option. i will tell you guys what it says then and we can go from thier. thanks for your input
Old Feb 19, 2004 | 07:53 PM
Fatdog's Avatar
Cool
My brother inlaw had the same problem with his truck.It was the o2 sensor.Hope this helps.
Old Feb 20, 2004 | 12:59 AM
superkia8's Avatar
I had that exact same problem for a few months, replaced just about everything from plugs, wires,egr, fuel filter, pcv and it wouldnt go away? Well it ended up being the o2! So if I were you I would go with that one? I did all the smaller things first and thats where I ended up. But then thats just me?
Old Feb 20, 2004 | 02:47 PM
cndctrdj's Avatar
well autozone scanned it and said it was the map sensor. but i think i am gonna change the o2 sensors too cause they (if im not mistaken) are original and the car has 147k on it
Old Feb 20, 2004 | 02:58 PM
superkia8's Avatar
YES , with that many miles I would definately start with the o2s!
Thanks,
Rich
Old Feb 20, 2004 | 04:03 PM
camaroguyo's Avatar
mine has 91k on it and i just had to replace the ignition module, one of the coils, all new plugs and wires,all the 02 sensors and the cat.
Old Feb 20, 2004 | 06:11 PM
superkia8's Avatar
Just think though, all of those items are maintenance items that would need replacing anyways. I just replaced all of those things just trying to fix that damn 2000 rpm stumble! I dont wish that problem on anyone, biggest pain in the $&* when you commute a long way to work everyday
But all is well now or for now I should say!
Good luck with the stumble, I feel your pain!
Rich
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
