Cheapest place for a Throwout Bearing?
Old Aug 5, 2003 | 04:29 PM
Black6SpdTA's Avatar
Where can I get a Throwout Bearing for the cheapest? '97 T56 (if year matters?) At Advance auto its $100 and the dealer it's $157 . Where else? Thanks
-Rippin
Old Aug 5, 2003 | 04:41 PM
RedPhenx's Avatar
napa... the little steel thing is like 20 dollars, if we are talking about the same thing. I just replaced it, looks like a little ball
edit: this was for 95 T/A but i assume it's the same
Old Aug 5, 2003 | 06:55 PM
Same thing as a "Release Bearing." Is slides over the input shaft and pushes on the pressure plate (is pushed by the clutch fork). You might be talking about the pilot bearing, it's really small.
-Rippin
Old Aug 5, 2003 | 07:43 PM
hsyr's Avatar
I bought a throw out bearing from SPEC for $25. Give them a call 1 - 800 - 828 - 4379 .
Old Aug 6, 2003 | 07:52 PM
1slowlt1's Avatar
Re: Cheapest place for a Throwout Bearing?
-Rippin
are you sure it is the throwout bearing? i got a self aligning one from jegs for $40. i didnt need it because the PP came with one. i still have it if you want it, brand new still in box.
rob
Old Aug 6, 2003 | 08:28 PM
RedPhenx's Avatar
yeah... im trying to figure out what the heck costs 157 dollars..
Old Aug 6, 2003 | 08:31 PM
1slowlt1's Avatar
me too, i even have a roller pilot bearing that is brand new and it was only $15.
rippin
if you want these pm me and let me know.
rob
Old Aug 6, 2003 | 08:54 PM
I went to Advance, then the dealer. Told them I needed the throwout bearing. That's what they told me. I couldn't believe it at first either. My pressure plate didn't come with one so I obviously need one. Let me do some more checking. Thanks guys
-Rippin
Old Aug 11, 2003 | 05:19 PM
TTT
As far as I know I'm going to have to go with the $100 from Advance
The Hays Self Aligning one from Jegs for $40 doesn't work I heard. It doesn't come with the clips to go onto the P/P and the inside/outside diameters are wrong. How about the "Oversize" one? Help!
-Rippin
EDIT: I'm talking about this http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361
one. P/N 490-70-104
Old Aug 11, 2003 | 05:27 PM
95 Z/28 LT1's Avatar
Super Moderator
Well, I bought a T.O.B. from Advance, but I got them to price match Jason Chromers price. I don't remember exactly how much I paid but it was still at least $75. The problem is, is that the LT1 P.P. uses a pull style T.O.B. and most everything else uses a push style. Face it, they are just expensive.
It did not come with the c-clip wire either. You may have to try and ask for one in the Parts Wanted section of the board, or at a local junkyard.
Good Luck!
Devinfoote87
Feb 12, 2016 03:21 PM
350350
14
Aug 11, 2015 12:03 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 7, 2015 07:19 PM
