Cheapest place to buy electric water pump
Where can I get a CSR cheapest?
I found this out at summit, made for LT1 says 30-37GPM, what GPM should I look for?
Re: Cheapest place to buy electric water pump
Steve
hmm, if you wire up the CORRECT warning system, this is not a problem. Plus, its easier to bolt in a new electric pump then to have to tear your motor down twice because the LT4 Extreme Duty timing set is a pile of sh*t and twice the water pump drive gear chewed into the cam gear and sent metal throughout my motor. It is worth every penny and every headache to NOT pull the freakin motor out again! (just my experience.)
I got mine from jegs with my racer discout. 146.99.
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
