changing valve springs w/ heads on car?
Old Mar 6, 2003 | 04:05 PM
  #16
Don 97 SS's Avatar
Originally posted by turbo_Z
you have CNC heads so they may have been machined already. 1.50" OD locator wont fit on stock heads. this is the only reason you cant install 987 springs on unmachined heads... the locators supplied are too large.
Brad, you may be correct, I had the heads done in '98 and don't recall all the details of the work. However, as I mentioned, Crane made these dual springs to fit bone stock heads. They are 1.46" OD and one would need a seat/locator at least the same size or slightly larger. Heck, I think the .015" hardened shims Crane supplies are 1.50" OD. I don't think CNC would waste the time milling the seat pockets a measley extra .004" or something. So I think my pockets are oem size. I really believe that since a Crane spring with 1.046 OD fits the pocket then a 1.50" seat/locator could easily be made to fit. That is what I did.
I don't know anything about CC987 springs. I haven't considered those.
Old Mar 6, 2003 | 04:11 PM
  #17
Don 97 SS's Avatar
Originally posted by shoebox
If you don't check the spring height, you don't have a clue if you are getting the valve seat pressure the spring was designed to give. You want to check it so you know the pressure is not too high or low. IMO, it does not make any sense to shop for a set of springs based on this or that spring pressure and then not measure them when you put them on.
Sometimes what you you don't know won't hurt you. Other times it will. I guess it does not hurt most people, since it seems that 75% of the people putting on springs did not measure them.
I'm not an expert on head work, but the procedure is a standard one.
Shoebox, I couldn't agree more! There is little doubt that an engine will run if you just throw the correct set of springs in. But if you desire the Nth degree of high performance and durability at high RPMs, one must verify the correct installed spring height.
Not checking reminds me of that old saw..."Ignorance is bliss"
Old Mar 6, 2003 | 04:26 PM
  #18
Momar's Avatar
I have never done this and have only installed one set of springs and it was on a Gen 1 350. I am curious, what do you do if they are off? Also, are these locators something used speicifically on alum heads, or what exactly task do they perform. I havent ever had to mess with them.
Ben
Old Mar 6, 2003 | 04:43 PM
  #19
Don 97 SS's Avatar
Ben
Check this CompCam's tech site for info on setting up springs.spring install info
Old Mar 6, 2003 | 04:57 PM
  #20
Momar's Avatar
Well, I read through that. So what do you do if you have taller valves? I would assume that they make taller springs? Are the locators something that is required or just a good idea? What difference does that make compared to just letting the spring sit in the spring pocket assuming it is shimmed properly? Sorry, but I have not done much with this kind of stuff and hadnt really been inside a motor to much until about a year ago.
Ben
Old Mar 6, 2003 | 07:52 PM
  #21
D James's Avatar
well I installed some springs on my big block without checking for the height, I had the toll to check it, but couldn't find it so I just took my chances, well It took one good run down the road winding it out to about 5600 rpm and bent about 8 pushrods, so to everyone that wants to take chances this can happen to you. But I did ask Cmotorsports about my cam and they said with most of their cam sales people usually don't check for height. My cam was pretty big it was something like 320/340 610/620 I don't remeber the exact numbers but I was really taking chances. Our pushrods are pretty cheap at 25 bucks, but it is kind of a pain to have to change them again. I suppose other worse damage could occur like bent valves or damaged pistons, so for the little extra work it should be done when doing the install, I guess with most guys here, you can get away with not checking, I still can't find my tool, so I might take chances again, unless I can rent one.
Old Mar 7, 2003 | 06:50 AM
  #22
Don 97 SS's Avatar
Ben
If your valve stems are long, you might need to add shims and/or go with a taller spring with a higher installed height.
Many believe that a good spring locator will keep the spring from walking around on the head at high RPMs.
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
