Changing Radiator this weekend....
Old May 1, 2009 | 02:26 PM
derrickgott007's Avatar
Like the title says I'm changing the radiator this weekend, as its origional and since I put the origional 18# cap on its falling apart (Tubes are splitting and its corroded). Is there anything I should be particularly careful about?
I've read and re-read shoebox's guide to refilling the radiator so I know about the venting. Should I flush the block since I used a bottle of Bar's Leak liquid aluminum radiator stop leak? Should I check the thermostat too to make sure its not clogged with stop leak?
Old May 1, 2009 | 03:20 PM
anyone? No internet access at home so a reply by 5pm today is great.
Old May 1, 2009 | 03:31 PM
Z28Freak86's Avatar
Definately flush it out. I would also suggest changing thermostats. If you used the stop leak in your system, your at a greater risk of of getting the thermostat clogged open or close in the future. It cheap enough and easy to replace. however that could be done anytime you want. Otherwise follow shoebox's instructions and you should be ok.
Old May 1, 2009 | 03:43 PM
I'll just pull the thermostat and rinse it off. It was about 5 months old since i put it in.
Old May 2, 2009 | 12:34 PM
Ok guys, new question... My overflow bottle seems to keep filling but not draining back into the radiator. Where exactly is the lower hose for that tank? And why would it do that?
Old May 2, 2009 | 06:44 PM
andysc's Avatar
not trying to hijack your thread, but I'm also having this problem, so let us both know what is up with this.
tia
andy schuck
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Jan 23, 2015 01:13 PM
