changing oul pan gasket. . .
Old Aug 1, 2005 | 06:49 PM
snakethis69's Avatar
how the **** do u do it?
Old Aug 1, 2005 | 07:27 PM
FastZinTennessee's Avatar
Re: changing oul pan gasket. . .
You pay someone to do it.... or,
Drop the Y-pipe, remove oil level sensor, remove torque converter cover (A4), remove motor mount bolts, jack motor up, remove oil pan bolts, drop oil pan, work old gasket out, clean sealing surfaces as much as possible, thread new gasket in place. Assembly is the reverse of removal
Old Aug 1, 2005 | 07:48 PM
colossus's Avatar
lol that sucks
Old Aug 1, 2005 | 09:37 PM
1-bad-z28's Avatar
it's easier to pull the motor out and do it that way. Yeah it sucks.
Old Aug 2, 2005 | 12:36 AM
speed_demon24's Avatar
I don't know if its because I have a 6-spd or not, but I did mine in 1.5 hours. I was also doing the motor mounts though, so I had one loose so I jacked one side of the motor up. You don't have to take the pan off all the way or slice the new gasket to put it in either, just slide the new gasket around the outside of the pan and it will go right into place...
Old Aug 2, 2005 | 06:15 AM
what about that damn dib stick? thats whats keeping me right now, i could have slid it in but i cant get it around the stick.
Old Aug 2, 2005 | 12:01 PM
1-bad-z28's Avatar
pull the dip stick out
Old Aug 2, 2005 | 12:14 PM
Usmuscl398's Avatar
Would this be a good time to replace the dip stick?!
Old Aug 2, 2005 | 01:22 PM
screamin94Z's Avatar
i pulled the motor out to change my OIL pan gasket and yes you have to take the DIP stick out. it's possible to do it in the car but it is a pain. of course it's also a pain to pull the motor, you'll just have to decide what you want to do.
Old Aug 2, 2005 | 01:28 PM
96speed's Avatar
Probably easiest to drop the Kmember. However, its a piece of cake with a tubular Kmember .
Ryan
Old Aug 2, 2005 | 05:30 PM
well i have to do the torque convertor also so maybe when i do that i should do it.
Old Aug 2, 2005 | 06:06 PM
if i unbolt the dipstick will the tubing come out? when i get it out how do i put it back so it doesnt leak?
Old Aug 2, 2005 | 06:09 PM
ZMAN Z28's Avatar
Stick the tube back in, it won't leak.
Z
Old Aug 2, 2005 | 07:25 PM
alrighty lets hope ur right, there is only a single bolt holding it down that i can see am i correct to assume that this is the only thing holding it in place? and i can pull the dip stiock housing out then just put it back and bolt it up?>
Old Aug 2, 2005 | 07:55 PM
ZMAN Z28's Avatar
I haven't had the bolt in mines for atleast 5 years now. No leaks from there at least from there.
ZMAN
