Changing oil pump after blown head gasket, is priming needed?
Old May 23, 2007 | 09:57 AM
kgkern01's Avatar
I blew my head gaskets, had some milky oil, and I went ahead and put in a new oil pump with GM white spring. I let the pump soak in oil before installing, the car sat since Jan. Do I need to prime oil before startup?
Old May 23, 2007 | 11:16 AM
1racerdude's Avatar
Yes
Old May 23, 2007 | 11:25 AM
wrd1972's Avatar
What you did does not take the place of priming, yes you should prime.
I did this once and it worked well, pull the coil wire off and pull the two fuel injector fuses. Crank the engine over till you see some oil pressure on the gage, if you do not see movement on the needle pull the oil pressure sender unit off and look for pressure there. If you can get pressure in a timely manner then you will not need to pull the intake. I would not go cranking for extended periods of time.
Old May 23, 2007 | 11:50 AM
LiENUS's Avatar
Shouldn't crank for more than 15 seconds at a time and give the starter about 30 seconds to cool off between cranks...
Old May 23, 2007 | 11:51 AM
arcticz28the383's Avatar
I took my new pump apart and lubed the gears with assembly lube, worked good for me.
Old May 23, 2007 | 08:01 PM
Dan Parker '96's Avatar
If everything is done correctly (meaning you expect the engine to start within 2 revolutions) and you have pre-filled the oil filter then priming is not necessary.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 27, 2014 09:41 AM
