Changing my rear but staying with the 10 bolt
I blew my stock 10 blot rear. I'm only pushing around 350HP but the guy who owned it before me really beat on it. I am purchasing a used rear axle from a 97 Trans Am. Before I install it I want to bulk it up as much as possible. I am also changing the gear ratio to 3.73. What can I do to make it stronger?
Put good gears and center section in it. And start saving your money. If you don't launch hard or run sticky tires you will be OK for a long time. Put really sticky tires and launch really hard and you can kill it the first time out. That is just the nature of the 10.
BBB
BBB
Originally posted by THE HULK 95 Z28
Bro, I blew my rear, I have to replace it. It's the first sentence in this post. Wake up.
Did you check that the one from the 97 have the same traction control setup as yours?
