changing a headlight on a camaro isnt hard is it?
My headlight went so im gonna go pick one up and replace it, just wonderin if this is a PITA, peice of cake right, i dont see how it could be, but i seem to be mechanically challenged. Thnkas Cory
Its no problem at all. Just a couple screws and the plug on the back. Shouldn't take very long at all. Don't mess with the alignment screws or you will point the light into the tree tops.
Here is all the info you need to upgrade the stock lights with out changing anything else.
http://performanceworks1.com/headlightmod.htm
I did it a while back the difference is noticable especially on the back roads with the high beams on.
Do a search in the "appearance" section for "Sylvania Silverstar" and you will find all kinds of info.
Dec 4, 2014 11:56 AM
Jul 4, 2005 05:00 PM
