changed oil? now idles to low
I have a 95 z28 and we changed the oil and filter to a wix filter and havoline 10w-30 because thats what the manuel said but on the cap it said 5w-30 is it because of the thicker oil that my car dies at a idle? if so do i need to readjust the idle or change the oil to 5w-30?
Re: changed oil? now idles to low
Whats your mileage on your car???
When it starts up what happens to your oil pressure gauge???
I have 140k miles on my car and I use 20-50 royal purple since my oil pressure drops with 5-30 and i experience leaks coming from above the black tank where you hook up the oil filter to...
I doubt the weight of the oil is the cause of your idle problems. Maybe something got knocked loose during the oil change or it is simply a coincidence it started happening right after the oil change.
01-23-2015 01:13 PM
07-04-2005 05:00 PM
Rino1313
07-18-2002 05:16 PM
