Cell 16 (idle) BLM's. Right around 109-110
Old Oct 9, 2006 | 08:55 AM
wrd1972's Avatar
As the subject says, my cell 16 BLM's are hovering right around 110. Is this a problem and what can I do?
Most of the BLM's when under light to mediaum loads are around 120.
Old Oct 9, 2006 | 09:02 AM
Zeueses 97 RamAir's Avatar
Re: Cell 16 (idle) BLM's. Right around 109-110
is that at wide open throttle or idle wide open 124 125 is good 130 is bad
Old Oct 9, 2006 | 10:31 AM
wrd1972's Avatar
WOT is 128 like it should be.
The cells that concern me are idling, and ver very light throttle. They are around 110, sometimes 109.
Old Oct 9, 2006 | 12:18 PM
And both right and left banks are the same in Cell 16?
The reason its at 128 WOT could be because the PCM defaults to 128 when the other Cells are reducing fuel (less than 128). Could indicate a problem with running rich, correcting it in closed loop with the reduced BLM's, then getting a super-rich mixture at WOT because the BLM's default to 128.
Does your MAF sensor still have the screen? Has it been "ported"?
Do you have a data log that people could look at?
Old Oct 9, 2006 | 08:04 PM
wrd1972's Avatar
MAF is all stock with screen. I will try to get a data log. Left and right's are wihin one point.
Old Oct 9, 2006 | 08:53 PM
Ray86IROC's Avatar
Mine idles at the same kinda numbers with similar mods as well, 108-109 on the left bank, 109-110 on the right. Under a load it seems to be in the 120s for the most part. Wonder if it's the base MadZ28 tune or what?
Old Oct 10, 2006 | 01:23 AM
128 is to rich 125 is where mine are at at wot and im dynoing over 300 with 4.11s...usually its the o2s my freinds was at 130 with bryans tune at wot and at idle very rich you were crying at the end of each drive..
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
Double aught
Oct 2, 2015 11:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
