Cca-230-236-112
Old Nov 14, 2007 | 08:39 PM
pizzi-man's Avatar
Cca-230-236-112
Any body running this cam and if so, how do you like it. duation 230 236 lift (1.5) .510 .521 LSA 112
Old Nov 15, 2007 | 06:37 PM
rob97ss's Avatar
I run it in my 383 with 1.6 rockers.Overall its a good cam,not to radical with good street manners.With slp shorties,stock dual cat ypipe,48mm tb,stock injectors i made 370rwhp.I just installed Kooks LT's & 36lb inj didnt dyno or tune it yet,but hoping to be in the upper380 low 390rwhp.
Old Nov 16, 2007 | 09:18 AM
pizzi-man's Avatar
Thanks for the reply Rob. I will be installing this cam in my 383 instead of the hot cam I was going with. I have the afr 195 elimanitors and 1.6 rockers, 58 mm throttle body, 30# svo's and hooker long tubes.
